| Posted by LonnythePlumber on June 29, 2004 at 18:28:20: | |
| In response to Re: Shower leak | |
: : It is not hard, Turn off the main water; disassemble the hot and cold stems; take to supply house for correct new parts. You need to get right on this, because although you see a leak in the outside, water may also be seeping behind the wall, and as Martha says, this is NOT a good thing. When removing the stems be careful not to lose the fiber washers where the stem meets the valve body. LonnythePlumber |
| There are none. |
