| Posted by hj on June 29, 2004 at 09:26:49: | |
| In response to Re: closet flange placement | |
15" side to side measured from the center says the same thing in my book. : thanks Deb : I assume you meant 15" on each side from the center, correct? : venting is a whole seperate issue - I posted a seperate question... : : : Is there a standard distance to set a closet flange from the studs when roughing it into a room. I do not have the fixtures in yet and the walls are still open. I want to be certian to have enough clearence behind the tank and on the side to mount teh toliet. Thanks : : The center of the closet flange needs to be set 12" from the FINISH wall. You need 24" clearance in front and 15" side to side as measured from the center of the flange.
| There are none. |
