| Posted by jimbo on June 28, 2004 at 23:07:34: | |
| In response to Re: Plumbing pipes | |
: If you are talking about the water supply, then copper is probably the preferred system in alomst all parts of the country. There are a few areas where water chemistry is a problem for copper, and some well systems this could also be true. CPVC is found in some modular homes and other areas. No plumber in his right mind would put just a glue joint between 70PSI and your living room. Never heard of HDPE or Polypropylene being use. Polybutylene was used for several years, and hundreds of lawyers have retired rich off the lawsuits, which are not over yet. A system called PEX ( cross-liked polyethylene) is gaining in popularity rapidly. Old farts like me will be slow to accept it even if it is great.
