Re: Plumbing pipes
Posted by Sylvan Tieger on June 28, 2004 at 17:39:05:
In response to Re: Plumbing pipes
: Dear Sir,
: I am confused weather to use copper, HDPE, CPVC or Polypropelene pipes for plumbing.
: Please advise with the + and - of these pipes
: Thank you
: Rohit
Gas,Water,Waste,Vent,Above ground? Below Ground?
Local code?Acid/ chemical waste
Pressure? Temperature? PH Factor?
ALL are GREAT products if properly used and ALL FAIL if not used for the proper applications.
There is no one material fits all applications EVEN copper has it weak points
Replies to this post
