| Posted by LonnythePlumber on June 28, 2004 at 13:01:11: | |
| In response to Re: closet flange placement | |
: : Is there a standard distance to set a closet flange from the studs when roughing it into a room. I do not have the fixtures in yet and the walls are still open. I want to be certian to have enough clearence behind the tank and on the side to mount teh toliet. Thanks : The center of the closet flange needs to be set 12" from the FINISH wall. You need 24" clearance in front and 15" side to side as measured from the center of the flange. Deb, I am pleased to see your postings again. LonnythePlumber |
| There are none. |
