| Posted by Scott Denny on June 27, 2004 at 18:25:06: | |
| In response to Re: leaky flush tower | |
You have described a situation that has happened in my area recently do to a change in the way the water utility disinfects our drinking water. They switched to Chloramine which attacks some types of rubber. Contact Toto and they will send you a new gasket/s. : Hi - I have a toto ultra-max toilet with a g-max flush tower. I have 3 of these toilets and been using them without problems for 5+ years. All of the sudden, I got a leak on the tank where the g-max tightens to the tank. I thought, that's simple, just tighten it. It didn't work. After further inspection, it appears that there is only a leak whn the line is pressurized. I don't think it's leaking due to the gasket or the tightness of the nut holding the flush tower on. It seems like it's internal somehow to the flush tower. Anyway, I was hoping that someone may have had a similar problem, so I'm looking for advice. Thanks for any you can offer.
| There are none. |
