Re: Leaking Drain Pipe
Posted by Gary Swart on June 27, 2004 at 11:20:42:
In response to Re: Leaking Drain Pipe
You can't patch it from the inside or outside. You must replace the broken section. This will require you to break out the concrete that is over the pipe. You should determine what caused the break and correct that along with replacing the broken section.
Replies to this post
There are none.
