Re: Losing pressure w/ cistern & water pump
Posted by Hube on June 26, 2004 at 15:11:24:
In response to Re: Losing pressure w/ cistern & water pump
: When water is being used in the house (i.e. shower, etc) the air pressure in the pressure tank is dropping so rapidly that the 30/50 pressure switch is turning on the cistern pump about every ten seconds, instead of every 10 minutes or so (during shower). The switch shuts off at the correct max pressure. I tried replacing the pressure switch and that did not correct the problem. Pressure is held when water is shut off, rapid drops only occur when water is being used. Do I need to replace pressure tank?
: Marc
Check the air pressure in the tank, it should be 2 psi below the cut-in point of the pump. (when tank empty) Hube
Replies to this post
There are none.
