| Posted by PW on June 25, 2004 at 13:34:20: | |
| In response to Re: Toto Carlyle making strange noises | |
Terry, What puzzles me is that one would do it and another not. It will also happen after filling is complete and any donation is made to the bowl. The second Carlyle I installed, I spread the wax seal around a bit so not so much would compress into the flow as far. (the discharge is rather close to the seal) In my case the flange was sitting a bit high and there was a lot of compression. That was the one that does not make the noise. Wonder if it could be a case of just how level the floor and toilet are sitting in that the drip is hitting the side before reaching the bottom of the adapter?
: : I just installed a Toto Carlyle toilet. When I flush it it empties fine, fills up fine and the water stops running into the tank. However, I then hear a "tinkling" of water coming from the drain area of the toilet (either in the unifit adapter or in the porcelain part beneath the bowl/tank). I have checked the flapper - it is not leaking. I have turned off the water and the sound continues. The sounds continue for about 45-60 seconds. I called Toto - they suggested cleaning the fill valve and sent me instructions. I did that, twice, to no avail. Any idea what it might be?
