Re: Bathtub drain valve problem
Posted by e-plumber on June 24, 2004 at 16:31:57:
In response to Re: Bathtub drain valve problem
: The flip lever for the bathtub drain valve does work. I've opened it up and it looks like the pull rod has come unscrewed. I don't had access to the back side. Shall I just try to fish around by using a flashlight and little mirror and try to get it screwed back in? What if that doesn't work? Thanks
You may want to try and fish it out with a wire hanger with a hook at the end. Once it's out, reassemble it or replace the complete linkage.
Replies to this post
