Re: New toilet
Posted by e-plumber on June 23, 2004 at 15:05:30:
In response to Re: New toilet
: I would like to install a new toilet in a room of my house. This room sits on a slab. I have to run the toilet drain line approximaly 7 feet before it contacts main line. From the top of the floor the the concreat slab I have 7 inches. Is this enough room?
Reply:
It would depend on how far below the floor the drain is that you plan on connection to. You need to maintain 1/4" per foot pitch for a 3" drain line.
I'm not sure what you mean by, "From the top of the floor the the concreat slab I have 7 inches. Is this enough room?"
On a 7' run the pipe will drop 1-3/4", figure it out based on your conditions and the required pitch needed.
e-plumber
Replies to this post
There are none.
