| Posted by Terry Messersmith on June 22, 2004 at 18:55:14: | |
| In response to Re: Options for Sewer Line Slope | |
In 2000, I did an addition that tapped into the sewer line in the front of the house. I really do not think the line was 4". This addition is at the back of the house. It really is not practical to trench around the whole house. The man at the San Jose City Building Dept. told me that I should use a large sweep into the toilet. I really did not want to raise the floor of the whole bath room. I thought about looking for a short toilet and putting it on a pedastal. Maybe I can use a wall mount toilet! I figured that I would also have to raise the shower pan. : Most outside lines are 4". : Have you considered raising the floor of the addition, or at least some part of the bathroom? : : I am planning an addition to the back of my house (in San Jose, CA) that includes a full bathroom. The foundation for the addition is concrete slab with peremeter footings. I am looking for options to get enough slope fall for the sewer line. I was hoping to connect to the sewer line at a clean out at the back of my house. There currently is a concrete patio over the pipe. As far as I can tell (without digging) the end of the pipe is 3 inch diameter and is 12 to 15 inches below grade. The bathroom is 40 to 44 feet away from the clean out. Using the 1/4" per foot slope requirement for 3" dia. pipe will require 11 inches of fall for this line. This does not include the height of the long sweep that is required for the toilet. I know 4" dia. pipe allows for a 3/16" to 1/8" per foot slope. It does not make sense to neck down to a 3" dia. pipe. Can I find a low height toilet and build a pedestal to raise it up. I would also have to raise the shower pan. I have heard of sewage power ejection systems. Is this a reasonable solution?
| There are none. |
