| Posted by BAKER on June 21, 2004 at 20:58:12: | |
| In response to Re: Amtrol RP25 Pressuriser turns on w/out demand | |
: : My Amtrol water pressuriser turns on and off continously without demand. It does do it consistently. From basic research it seems like the check valve is the most likely culprit. I turned on the pump and turned off the supply to the pump and the pressure did not change - I understand this is a test for a problem check valve. Could I fix this? Could you recommend someone who is familiar with these pumps (are you? - I live iN UPPER MARLBORO MD. Thanks :
| There are none. |
