| Posted by hj on June 20, 2004 at 11:32:30: | |
| In response to Re: airlocked pipes | |
It appears that you are describing an English water system. They are a special "breed of cat" so a local plumber would be your best source to find a solution. : my water system has no cold water at the bathroom sink and at the toilet.there was an airlock,i solved the hot water by connecting the main supply to the hot water line and forcing it through.i then looped the hot water line to the cold line in the bathroom and connected the main cold line to the hot again(downstairs)but after reconnecting the lines the problem was still the same,any suggestions.thank you
| There are none. |
