| Posted by Sylvan Tieger on June 19, 2004 at 19:45:55: | |
| In response to Re: Hot Water Tank leaking??? | |
could also be leaking because of high water temperature, above 221F. : e-plumber Wow, and here I was a certified boiler and pressure vessel inspector thinking all this time that a standard T&P was set for 150 PSI or 210 degrees. (Ask and ILL explain WHY) The idea of placing something under the T&P is a good idea as long as it doesn't impede the flow of the relief. Chances are it could also be normal condensation. If the T&P is more then 2-3 years old it should be replaced as why take a chance on a $4.00 part |
