Re: Relocate water supply to install a Toto?
Posted by Terry Love on June 17, 2004 at 21:13:40:
In response to Re: Relocate water supply to install a Toto?
: Terry,
: Toto's Web site says the Vespin and other skirted models need a water supply rough-in wider than the standard 5 1/2 inches. The feature descriptions on your site say 7 inches left of center is required, and 8 is recommended.
: Does this mean I have to have my water line in the wall moved in order to replace my toilet? Or will a longer flexible connector do the trick?
If it's less than 7" center line to center of valve, yes.
If it's run in copper, you can solder a 90 el on and move it to the left.
Terry Love
Replies to this post
There are none.
