Re: slow refill/toilet
Posted by Deb on June 15, 2004 at 19:03:46:
In response to Re: slow refill/toilet
: I was hopeing someone could tell me how to find where the problem of the refill on the toilet is that is @ a trickle. I replaced the guts inside the toilet and also checked the shut-off valve and still refills very very slow.If its a clogged pipe under the mobile/h, how do i know where to replace it?? thanks 4 any advice ,Bruce
What exactly do you mean when you say that you checked the shut off valve? What did you check? Did you have good pressure? What kind of water lines do you have in your mobile home?
The Pipewench
Replies to this post
There are none.
