| Posted by e-plumber on June 13, 2004 at 23:11:42: | |
| In response to Re: toilet flange | |
: I recently repaired the floor in my bathroom and am trying to replace the toilet flange. My problem is the 4" cast iron pipe does not protrude high enough to get a good seal on the closet flange that has the adjustable rubber gasket. The CI pipe has jagged edges, it has been cut unevenly. : My question is do you recommend the "Twist and Set" kits? I noticed they reduce the size of the waste port to less than 3". This may be my only alternative. Reply: |
| There are none. |
