Re: How dangerous are sewer fumes?
Posted by jimbo on June 13, 2004 at 19:25:00:
In response to Re: How dangerous are sewer fumes?
: Applying ABS solvent to the OUTSIDE of a pipe is NOT and adequate repair, no matter what the plumber or your landlord tries to tell you. If there is a bad joint, it must be disassembled and reglued. If there is an actual hole for some reason, this pipe or fitting must be replaced.
Replies to this post
There are none.
