| Posted by Jim Hahn on June 09, 2004 at 09:58:12: | |
| In response to Re: No leaks around the flange though | |
I had one of these pin hole leaks too. Before we knew what it really was, the pin hole leak was just a theory. We removed the toilet bowl and turned it upside down and dried it. There is a small channel between the bottom of the bowl and the drain hole area. We speculated there was a pin hole allowing the bowl to drain. To test the theory, we plugged the channel up Kohler and others seem to have this little |
| There are none. |
