| Posted by Jim DeBruycker on June 08, 2004 at 20:09:02: | |
| In response to Re: Garbage disposal frozen | |
Just to make sure, there usually is a hex hole in the bottom of the motor shaft that you can put a hex wrench into. This is not an external head like the head of a bolt. Every once in awhile, they'll put a plastic plug in it, which makes it hard to find if you don't know. |
| There are none. |
