| Posted by Tony on June 08, 2004 at 14:37:09: | |
I recently purchased a used Sears shallow water pump(no manual) and can not find any info on it. The problem is I can not get pressure on the water gauge, I insert around 30 psi in the pressure tank and can not get much pressure when I turn the pump on also it stays on even when I turn off spigot.If the bladder is ruptured can it still take air,I noticed that the psi will slowly diminish. Tanks for any help! |
| There are none. |
