| Posted by hj on June 07, 2004 at 09:01:38: | |
| In response to Re: EXTREMELY NOISY CAST IRON DRAIN PIPES !!! | |
It is the difference between the noise a waterfall makes and a river. Falling water will always be noisier, and without modifying the plumbing, or building, you may just have to live with the sound. : Terry, : We've just had a couple of Toto toilets installed on a new home. When flushed it sounds like a waterfall going through the walls. We thought it was the speed of the water exiting the toilets....but the same amount of noise from the bathtub draining as well. : Thanks!!!
| There are none. |
