Re: EXTREMELY NOISY CAST IRON DRAIN PIPES !!!
Posted by Terry Love on June 07, 2004 at 03:30:09:
In response to Re: EXTREMELY NOISY CAST IRON DRAIN PIPES !!!
Jeff,
If the tub also makes a racket when it drains, then maybe you have plastic pipe.
Most new homes have plastic, not cast iron.
ABS is black, PVC is white.
Without going into the walls, it's a bit tough.
They make a tape that reduces noise that can be applied.
The wall cavity can be insulated too.
However, most drains for the toilets are 3" ID with a 3.5" OD.
Figure about 4" on the hub of the fitting, which the drywall bends around to fit on the wall.
Anytime you have drywall touching the pipe, it will be louder.
: There seems to me much more noise in the vertical cast iron pipe than in the "horizontal" portions in the basement. What are some causes and solutions
: Thanks!!!
Replies to this post
There are none.
