Re: Ice maker pump drain
Posted by hj on May 31, 2004 at 21:40:14:
In response to Re: Ice maker pump drain
If the drain is "loose" in the pump so that it will overflow the pump in the event of a malfunction, and you use a dishwasher air gap fitting so that there is absolutley no possibility that the disposer water can back up into the icemaker, then yes. Because an icemaker is continually "melting" the ice, and the bin is always filled, any backup would not be discovered immediately and the ice could be contaminated before it is discovered.
: Is it legal to terminate a ice maker pump drain into a garbage disposal inlet {diswhasher drain inlet}???
Replies to this post
There are none.
