| Posted by Terry Love on May 31, 2004 at 20:46:52: | |
| In response to Re: Turning a toilet 90 degrees | |
Building code is 15" from center line to the wall. The inspector may have allowed it for you, but it's not code. That and you should have 24" in front of the toilet, with a round front toilet on a 12" rough, you would need a room 51.25" deep. : : Minimum distance to each side of a toilet is 15" from the center. Sounds like it's too close on the sides now and will be too close if you turn it. Might be time to look at Plan B. : Inspector did not say anything was wrong at the rough-in inspection. I've only got 13 inches on the one side. Wouldn't he have said something at the rough inspection if it was a problem?
| There are none. |
