| Posted by Jason on May 31, 2004 at 19:41:22: | |
| In response to Re: copper pipe size in treatment system | |
: : Gary : : Quality Water Associates : Hi Gary, : RE:We water treatment guys use flow controls when needed, not undersized tubing and for a solution feeder, there is no need to control the flow. : Many times rather then go for a mechanical device like "flow control devices" we can do it math mathematically. : For example if a filter has a rating of no more then 20 GPM to remove sediment all one would have to do is find the in coming pressure. : Lets assume that the available pressure is 65 PSI and we are running 3/4 lines, the volume flowing would hover around 39.37 GPM thus rendering the filter useless. : Now if the installer used 1/2" prior to going into this filter the VOLUME flowing through this piping would be 17.5 GPM still well with in the filters capacity to remove sediment without causing undo turbulence. : This is especially true on acid crock systems, like a floor drain in a battery room or in a laboratory where this acidic waste has to be controlled prior to entering the neutralizing tank. : Too fast and the marble chips will not have time to do their job and not every installation has room to have a holding tank. : Thus we have to depend on piping sized to reduce volume rather then figuring baffles or mechanical devices that are prone to failure : : Older heating steam and hydronics depended on piping being increased or decreased depending on what the condition needed. : Hey its just another train of thought Hey Sylvan, your confusing folks with facts and giving techs a bad name. |
| There are none. |
