Re: Turning a toilet 90 degrees
Posted by chriss on May 31, 2004 at 17:01:50:
In response to Re: Turning a toilet 90 degrees
: Minimum distance to each side of a toilet is 15" from the center. Sounds like it's too close on the sides now and will be too close if you turn it. Might be time to look at Plan B.
Inspector did not say anything was wrong at the rough-in inspection. I've only got 13 inches on the one side. Wouldn't he have said something at the rough inspection if it was a problem?
Replies to this post
