| Posted by chriss on May 31, 2004 at 15:49:45: | |
| In response to Re: Turning a toilet 90 degrees | |
: : I have just put in a small half bath and the front of the toilet is quite close to the vanity. I knew it would be close but for anyone over 6 feet or so, it may be kind of tight when sitting. : : Can I turn the toilet 90 degrees without removing the flange from the closet bend? Is there an adapter to do this with or am I faced with removing floor and cutting off bend and installing new? : : FYI the current flange is 13 inches from one wall an 12 from the other. : Depends on the kind of floor flange you now have there. : What about your water supply? I have a standard, cemented ABS flange and the water supply is PEX. Suppose it has to be moved now that you mention it. |
