| Posted by Sylvan Tieger on May 31, 2004 at 15:30:46: | |
| In response to Re: Turning a toilet 90 degrees | |
: I have just put in a small half bath and the front of the toilet is quite close to the vanity. I knew it would be close but for anyone over 6 feet or so, it may be kind of tight when sitting. : Can I turn the toilet 90 degrees without removing the flange from the closet bend? Is there an adapter to do this with or am I faced with removing floor and cutting off bend and installing new? : FYI the current flange is 13 inches from one wall an 12 from the other. Depends on the kind of floor flange you now have there. What about your water supply? |
