| Posted by Terry Love on May 30, 2004 at 19:40:50: | |
| In response to Re: 10 inch rough toilets | |
: Hello, : We have a 10inch rough flushometer toilet currently and need to replace it. I would like to get another 10" rough toilet, but one with a tank. On consumer reports many of these toilets get poor ratings. What would you suggest? Thanks! Sarah, If you switch to a tank, you will need to move the water supply at the wall and change it to a half inch supply stubout which can reduce to something like 3/8" OD. You may want to consider another Flushometer style bowl and use a new 1.6 gallon valve. If you do switch to a tank style toilet, Geber makes their Ultraflush with a offset tank that allows for a 10" rough.
| There are none. |
