| Posted by e-plumber on May 29, 2004 at 13:46:59: | |
| In response to Re: Kohler Rialto K 3386 valve | |
: I also have an older Rialto that flushes better, but the finish on that one has been damaged from caked up minerals and repeated cleaning with chemicals. The inside bowl configuration on the older model is harder to clean because of that channel from the tank at the bottom of the bowl. : On the current model Rialto, I priced out the new valve and it is about $68 plus tax and shipping. I am wondering whether this toilet is even worth all the trouble, as I have to special order this...the local Kohler supply house ( a large distributor) doesn't even have one in stock nor does Home Depot who has this s-house as a stock item. : Also, are there any extensions/modifications for the overflow tube that I can retrofit to put some giddy-up on the flush with some added tank level? Reply: |
| There are none. |
