Re: dishwasher into main stack
Posted by e-plumber on May 29, 2004 at 13:37:40:
In response to Re: dishwasher into main stack
 : i have remodelled my kitchen and now want to hjook the dishwasher drain directly into the main stack which is only about 4 feet from dishwasher. it was connected to the sinks about 12 feet away. Can I do this and how do I go about it. I noticed on your bulletin board Brad McMullin and Peter Welsh asked the same question sonme time ago Reply: Connecting the DW drain directly to a drain stack is illegal in any plumbing code. I'm still trying to figure out why the DW would be 12' away from the kitchen sink... To properly make a drain connection, you would either need to connect it under the kitchen sink upstream of the drain trap. If that is not possible, an island drain/vent installation can be done, which is quite involved and is not a DIY project. Whether you need an air gap for the DW drain mounted on your countertop will depend on what your local code dictates. Here, we use the high loop drain method for residential DW's. e-plumber
