Re: Kohler Rialto K 3386 valve
Posted by e-plumber on May 28, 2004 at 16:47:08:
In response to Re: Kohler Rialto K 3386 valve
: I have a Rialto K3386.
: I replaced flapper thinking that might be the problem but still the water keeps running even if I lift the arm on the valve all the way up.
: The valve is marld "Kohler 703." Should I order one from a supply house or is there a simpler fix or replacement valve.
: By the way, this is a terrible toilet thta I would not recommend. It does not flush at all, but I have two of them in small spaces where bigger front to back dimensions would not work.
Reply:
If your fill valve looks like the picture above, it is Kohler number 1007488 for the complete fill valve. I have had to replace several over the past couple of years. You may be able to rebuild the fill valve by replacing a rubber gasket inside of it. The Rialto has always been a problematic toilet, I have one in my house that is 15 years old (3.5 gpf) and it flushes great. You know it's a problem toilet when Kohler installs a troubleshooting guide under the tank lid.
e-plumber
Replies to this post
