| Posted by hj on May 27, 2004 at 23:57:47: | |
| In response to Re: turn on the cold water line and all h#ll breaks loose | |
About 30 seconds or less. It is probably not air. It is usually a bad valve, but it depends on when the noise occurs. Is it when the valve is being opened? When the faucet is being used? Or other time? : How long should it take for the air to get out of the pipes.
| There are none. |
