| Posted by Sharon on May 26, 2004 at 18:58:29: | |
| In response to Re: Does 90 psi require a pressure reducing valve? | |
: I have 90 psi pressure measured in my basement. According to the town and the water company I dont need a pressure reducing valve at that pressure (I did not think to ask what pressure I would need one). : I'm somewhat surprised by this because they are pretty particular about sprkinler systems (RPP valves are required as is a yearly test by the water company) : Does that seem too high? Am I going to have long term damage to my appliances with 90 psi? : Thanks, Sylvan, as a third year engineering student, I have to commend you for stating why. I see a lot of posters give code but do not go into details and sometimes it is important to explain the why not only how. Thank you and I did recalculate your numbers and your correct as if you didn't know. :-) (((((((((((Sylvan))))))))))))))) |
