| Posted by e-plumber on May 26, 2004 at 17:45:30: | |
| In response to Re: bathroom shower leak-from where? | |
: : : Bathroom addition has corner shower(prefab)-it leaked under the showe ronto the floor and into the wall near the floor-wall was cut behind shower head and no pipes leading to shower were leaking-pan replaced-still leaked-shower floor rebuilt and prefab floor was replaced with tile -two different projects-still leaks-doesn't leak when water is poured into drain-only when shower is flowing-no leak behind wall -only from under-how can I find the source of the leak so I can get it fixed? : : Reply: : The wall was opened and everything was dry-any other possibilities-is there a way for the water to leak at the drain in a way that pouring directly doesn't causes leakage?? Very appreciative of any hlp-this has been a mystry and a headache! Reply: |
| There are none. |
