| Posted by Sylvan Tieger on May 26, 2004 at 13:47:14: | |
| In response to Re: Noises in my hot water heater! | |
: My gas fired water heater is just about 2 years old, and at the time it was replaced, my whole modular home was repiped with copper... : for quite some time now it has been "gurgling" and "gargeling" right after a shower. : ...Could the acidity of my water cause it to be on it's way out? : ...Do I need an expansion tank? : I think it's just air it the tank... is there a way I could bleed it off? : Thank you in advance! : Mike If it is "air" from possible minerals in the water I use a Hoffman #76 BUT I keep the water pressure below 70 PSI even though the working pressure for this air vent is around 80 As I leave room for expansion (pressure temperature relationship) |
| There are none. |
