Re: Noises in my hot water heater!
Posted by jimbo on May 25, 2004 at 23:43:38:
In response to Re: Noises in my hot water heater!
: Rarely if ever will you have air in your water system. If you do, you will have spurting whenever you use a faucet and the air will bleed out.
A water heater can make noise due to buildup of sediment or mineral deposits on the base of the tank. The buildup causes local boiling under it and this agitates the sediment. 2 years is pretty young for this, but try flushing the water heater anyway to see if that helps.
Replies to this post
There are none.
