| Posted by Weogo Reed on May 24, 2004 at 23:34:46: | |
| In response to Re: Under slab leak - What now?? | |
Hi Mitch, : We had an intermittent leak which was originally diagnosed as a pinhole leak which was sometimes plugged by debris. It turned out to be a leak in a pipe under our concrete slab. I'm a big fan of running under-slab plumbing in chases... : It was probably leaking for months. After location by a detection service it was repaired by re-routing through the attic. The carpeting in several rooms and hallways smelled musty and were removed by the remedidation service recommended by the insurance company. After 3 weeks of dehumidifers and fans, a calcium chloride test shows higher levels than recommended for carpeting (5 gal/day/1000 sq ft). What do we do now. I would want to know if the soil under the slab is moist because of the leak, or has it always been wet? Does the rest of your property have high soil moisture levels? If the moisture is just from the leak, you likely need more time with the dehumidifiers and fans. Good health, Weogo |
