| Posted by hj on May 24, 2004 at 22:08:20: | |
| In response to Re: Sewer relining rather than replacement? | |
As long as the roots are completely removed so they do not cause bumps in the liner, and the pipe is relatively straight so you do not reline a porly pitched or deflected sewer, you should be in good shape. It is a process that many cities use to repair their sewer mains. : Hi folks, I hope someone here has the experience to give me some advice. : I live in an 87-year-old house whose sewer line is probably the same age. I wasn't smart enough when I bought the house to have the line camera-ed, find the problems, and subtract the cost of the replacement from the house price :-( : Long story short: the sewer line is in really bad shape (it's clay), and I have constant trouble with roots from the trees that live right above it. To dig and replace will be expensive - it's in a fantastically tight and inconvenient location, and half the length will have to be dug by hand, down to about 8 ft :-( I've had a bid to reline the pipe with what I believe is called "cured in place pipe". It's like a vinyl sock that they blow down the tube, fill it with hot air, and it cures into a rigid lining inside the old pipe. : I've had a couple local plumbers tell me they think it's a band-aid - they don't believe in it. Others have never heard of it. The cost to do this is half of the cost to dig. I know it won't be as good as a new pipe, but if it'll last even 10-12 years, that may be good enough. : Does anyone have experience with this stuff? Should I get the lining? Thanks very much for your help.
| There are none. |
