Re: How to remove a porcelain sink without breaking the tiles?
Posted by jimbo on May 24, 2004 at 15:22:39:
In response to Re: How to remove a porcelain sink without breaking the tiles?
:That piano wire thing is the best suggestion I ever heard; I was not onto that one. You CAN teach an old dog new tricks! If it is only putty under there, you are in luck, because it may have hardened, but it will not have very much holding strength, and can easily be popped up. Piano wire trick should solve all the problems.
