Re: no water pressure
Posted by Deb on May 24, 2004 at 01:08:45:
In response to Re: no water pressure
: i recently had to relace my well pump tank,it was rotted out on the bottom losing water everywhere.went to home depot and bought new pump tank.weird that the old one had an inlet and an outlet but the new one has one hole for in and out going water supplies.i installed as directions said to do.now when ever i open a faucet,washing machine or shower no pressure at all.the tank came pre-charged at 40 psi. so iset the pressure switch to turn on ay 42 psi and shut off at 62 psi.please help getting very frustrated and do not want to call a plumber.feel free to email me with a reply.
What exactly do you mean by "no pressure at all"? Do you mean no water or do you mean poor pressure?
Anytime you work on water lines you break loose pieces of debris that can clog faucets, valves, aeratots, etc. greatly affecting your water flow. If you have old galvanized, debris could be clogging virtually everything.
Deb
The Pipewench
Replies to this post
