Re: Uneven hot/cold water pressure
Posted by jimbo on May 23, 2004 at 20:36:38:
In response to Re: Uneven hot/cold water pressure
: Sylvan, let me ask this question because I do not know the answer and you probably can figure it out:
If you have the PRV on the inlet to the water heater, then you put a pressure balanced unit in the shower, wouldn't these two devices try to work "against" each other? Just a thought.
Replies to this post
There are none.
