I removed the stopper to clean it and now I can't get it positioned so the rod will BOTH open and close it. It seems no matter which hole is used in the plastic stopper thingey, the range of motion is not enough to do both. This is BEFORE I attach it to the vertical push-pull rod so the full range should be available to me as I move the bar up and down. Also there are two little plastic washer things that look like half moons. One is in front of the ball and one behind. Is this correct? Thank you, Cactus Blossom
