Re: Replacing the cast iron main drain with pvc
Posted by Gary Swart on May 23, 2004 at 10:36:01:
In response to Re: Replacing the cast iron main drain with pvc
You have to use a no-hub connector if it will be buried. The neophrene Fernco connectors are OK above ground. Both connectors use stainless steel bands, no O rings.
Replies to this post
There are none.
