Re: main water supply
Posted by hj on May 22, 2004 at 22:38:37:
In response to Re: main water supply
There will always be a shutoff at the meter, although, you being a novice, may not have the proper tool to turn it.
: : : You didn't say where you live. Here in So. California, it will almost always be right at the front of the house, or on newer houses in the garage. There will also be a shut off at the meter box right next to the sidewalk in front. If you live where it is cold, none of these will be true.
: it goes back to that whole novice thing....we live in michigan so i'm assuming that none of those suggestions apply...but thanks
Replies to this post
There are none.
