| Posted by hj on May 22, 2004 at 09:42:45: | |
| In response to Re: Air Gap for Sump Pump? | |
You mean an air chamber. It will not help. The bang is the check valve closing and is caused by the weight of the water pushing it closed. You need a check valve with a rubber disc, which will help reduce the noise considerably. : My sump pump always cuts off with a big bang - just like a water pipe without an air gap.
| There are none. |
