| Posted by hj on May 20, 2004 at 10:49:53: | |
| In response to Re: Undermounted sink pulled away from granite countertop | |
Unless the sink "bent" there is no way it could just separate at the faucet area. It may be most apparent there, but there has to be a gap elsewhere, at least along the sides, which implies that the "clamps" were either not strong enough or installed improperly. It would have been easier to install a framework to support the sink before the countertop was installed, but you should jack it back into place and then build a framework to hold it in place. Do not use props to the cabinet floor because that can sag if it gets wet or too much weight is placed on it. : I read with interest a posting on April 3, 2004 regarding this same subject. In our case one of the clips came off. We called the original granite installer but he has not gotten back with us. I called a plumber and they said we needed a granite guy. Go figure. My husband built a support frame underneath the sink but we are not sure if we have to remove the sink entirely to re-caulk it or if we can just squirt some caulk in the areas where it has pulled away. I personally do not want to take out the clips that are there and take a chance when we put them back in that the granite might crack and also have to reattach plumbing. Since the sink has only pulled away under the faucet part can we just put caulk under that part, and install the wood brace underneath the sink? There are still 3 clips on both sides of the sink. Only the one on the back by the faucet fell off. These clips don't seem to be the best way to install such a heavy sink anyway. Please advise.
| There are none. |
