| Posted by LonnythePlumber on May 18, 2004 at 09:18:01: | |
| In response to Re: Hot water heater leaking | |
: My hot water heater is leaking, not through the relief valve pipe but through the tank drain fixture. Is there a washer on these that can be replaced? A hose cap will also serve as will replacing or turning over the push on washer. The best would be to replace with an extended brass drain. LonnythePlumber |
| There are none. |
